in your opinion what is the best light option?? different than the stocks
josbeat
483
spain
option 1
only one high and low 50 mm proyector on each side
option 2
two 50 mm proyector , two low beam and two high beam
option 3
same as option 2 but flush monted with a clear plastic cover like this.
josbeat
483
spain
the reason is the weight
all front light system weight 8 kg in total
each of the 50 mm projector 250 grm
Enraged
A HG job took HOW long??
21
Victoria, BC, Canada
option 1 would be the lightest, option 2 might block some airflow to your radiator, option 3 flushmount has been done before so you know it can work. would you need to keep the stock lights to be street legal?
miekedmr
mkiii in hibernation
Jul 12, 2005
511
Upstate NY
Of those choices I like option 1 the best.
Have you considered a mix of option 1 and option 3? I never liked the idea of putting low beams in a flush mount in the stock location because of how much bumper is in the way... But for a high beam the flush mount would be fine. for a low beam I like the grille placement better.
josbeat
483
spain
no need to keep the stock ones but yes i need a street legal lights to keep it running on the streets.
and really it will not make any problem with the cooling system
josbeat
483
spain
not really but that option will be to much work
the idea is to do something simple and lighter but also with a good looking
